Old 07-30-2021, 07:29 AM   #5
Quadcammer
Originally Posted by MaxD View Post
If you are going to a push to start button, why not ditch the lock housing.
You need to keep the key and the antenna together for the immobilizer. Wire up an ignition "on" switch and then a button for the starter.
I have not done this yet but this is what I intend to do after the season is over. The Bentley wiring schematic looks simple for this mod.
I can promote it since I haven't done it.
Otherwise the photo reference trygve posted is spot on.
I'd be happy to do so. I was not sure where the ignition "induction ring" was, i figured it might be contained in that assembly. The key pill needs to be next to that, so if its separate from that part, I'm happy to junk the whole lock assembly.
