Old 07-28-2021, 08:22 PM   #32
Walshie
Originally Posted by Earnest View Post
Walshie, Thank you so much! I think I found Meir's posts--there were actually three different documents he put on DropBox. One for removing the heater core, one for the dashboard, and the last one for removing and repairing the heater box. Does that sound like what you used? Did you do all three steps?
I actually responded to this post a couple of days ago but included the DropBox links to see if they looked familiar to you, but the forum said a moderator needed to review it before posting... I must have done something wrong because the response never posted.
Anyway, thanks so much again for the help. I completely understand the daunting prospect this project presents and the need to muster courage--definitely there myself, but I think I'm sufficiently psyched up to make a go of it this weekend. I am sure of the leak through the heater box pass-thru, but there might also be an additional leak source more toward the midline, possibly the heater core, so I'm likely to attempt all of Meir's three steps. Will let you know how things go, and once again I appreciate your help!
Best,
Scott
Hi Scott
Yes I did use all 3 posts. My advise is buy some zip lock food bags and a sharpie and put each set of fixings from each step in a different bag. Label them with the items and number them . Then reassemble in reverse order. I also took photos to remind me. It was actually quite fun in the end.
Good luck and let me know how it goes.
Walshie
Walshie is offline   Reply With Quote
