Originally Posted by Starter986
In the trunk. The relay box driver side. Slot/spot #10. I've switched power running a couple wires out of where the relay sits. I don't recall into where the two wires run. My mechanic brought to my attention that's where I'm missing the relay for the SAIS.
Power comes on when ignition is turned on. Shuts off power about 15 seconds after the key is removed.
Any chance you can post an image of this relay? Then I might be able figure out what is on that circuit and permissible current draw.
