Old 07-05-2021, 01:44 PM   #2
Stl-986
What I usually do for stuff like this is try to use the original. You should be able to use a very small flat screwdriver, pick, snipes to uncrimp the end of the wire. then when you put in the new wire, crimp it back...but also go ahead and solder it in. The solder will hold the wire in place in addition to the crimps. Done this on many 944's & other older cars.
Porsche will usually use TE for their connectors/pins With that said, Mouser does have these in stock: https://www.mouser.com/Search/Refine?Keyword=962842
Loose part: https://www.mouser.com/ProductDetail/TE-Connectivity/2-962842-1-Loose-Piece?qs=u4fy%2FsgLU9M4ir46pBsb1A%3D%3D
When looking for things like this you have to understand that one part number might be for reels and some might be for individual. Reels are what are used in the mfg process by machines.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
