Thread: Xenon Litronics
Old 06-24-2021, 04:57 PM   #5
KevinH1990
KevinH1990's Avatar
In addition to the guidance that PLP provided, you cannot rule out the possibility of deteriorated wiring inside the light assembly. You can check out my experience refurbishing a set of litronics in this thread: Advice on Used Litronics
I had a bad ballast on one light and deteriorated wiring in another. I was able to swap the working ballast between the two headlights and confirm that was the problem before I purchased a replacement. You may want to purchase one ballast to confirm that fixes the problem before investing in a second. I believe they are fairly expensive.
How did the seller know the lights were working when he shipped them? Did he remove them from his vehicle?
KevinH1990 is offline   Reply With Quote
