Old 04-14-2021, 11:15 AM   #2
Homeoboxter
Originally Posted by pilot4fn View Post
When the fans kick in, the temp creeps up another 0,5 C (to 100,5 C) and then comes down pretty quikly.
When I did the test, I had been driving over an hour. Turned the engine off, connected the Durametric, restarted the car and let it idle while occasionally given a bit or addittional rpm. This whiel following the actual values on the temperature with Durametric.
Yes, that`s totally fine, I did the same and had the same reading. Sorry for the confusion, my comment was referencing to the OP`s post about the temperature "still creeping up". I`m just wondering if the OP confirmed that the high temperature that he sees is indeed out of the normal range, i.e. way over 100C.
