If it's a dme problem it's a simple fix - get in, turn the key to on, press and hold window up buttons until windows are shut and then keep holding them for about 10 more seconds. Then give it a try. If it still drops too low then it's a physical alignment issue and you'll have to tear the door card apart and change where the mounts tighten down on the regulator cables (front and back).
Sent from my POCOPHONE F1 using Tapatalk
