Old 03-25-2021, 09:25 AM   #10
JFP in PA
Originally Posted by ike84 View Post
What material is that? Aluminum? I can't imagine you would have been able to do that to a steel plug. Aluminum on the other hand is not a material that I would consider using this application.
Sent from my POCOPHONE F1 using Tapatalk
Very bad idea. Every customer that tried using steel plugs instead of aluminum eventually ended up replacing their sump cover due to the damage the steel plugs caused. Use aluminum, the plugs are cheaper and easier to replace than the sump covers.............
