Originally Posted by mtb50
Look at Porshe convertible top fix by Burner's Cars. You will see the control arm has a plastic ball cap or socket. There will be an arm on the driver side and passenger side. With your seats moved forward and backs tilted forward take a flash light and look for these. Now find something that will reach into the ball cap and pop it off on both sides of the car. You should be able to lift the top to see where the problem is at.
Is that the arm you're referring to?
