Old 02-24-2021, 11:21 AM   #2
911monty
911monty's Avatar
The Pelican Torque converter seal is the correct part. Buy the Porsche seal. Even though the other is OEM my experience is they are not of equal quality. Not worth a few bucks difference.
Yes changing the RMS would be a good idea, But if it's not leaking and you are not going to use the proper installation tools, then might be best left alone. If you do want to change it, then purchase the upgraded seal and rent the tools from LNE. And I know some will say it can be done with DIY tools, it simply is not worth having to possibly pull the trans again for a mulligan.
Good Luck
