Old 02-21-2021, 02:03 PM   #5
ike84
The reason it is a pain to realign is that when assembled, that aluminum panel is under tension and keeping the uprights in their correct position.
I guess that I was actually more surprised that it came off without effort. I assumed that things had shifted slightly over the 6 weeks it's been off. Do you normally check alignment after reinstalling it? Is it like other suspension structures that should be torqued after the car is back in the ground. I didn't see that in the workshop manual but I figured it's worth asking.
Sent from my POCOPHONE F1 using Tapatalk
