Old 02-04-2021, 12:10 PM   #8
Farmlifer
Veteran & Boxster Padawan
Farmlifer's Avatar
Thumbs up
Originally Posted by rexcramer View Post
Nut driver, hand tight. Just be aware that you are going into plastic. I think I was using a 1/4" ratchet initially. I felt the first one starting to pull when I was reassembling. I was just replacing the O-rings and found it helpful to tighten the screws in a crisscross pattern (think wheel lug nuts) to keep them in place.
Thank you - will be very careful, check for leaks, then tighten further if needed
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
