I am trying to remove the fuel rails from my '98 Boxster (2.5L). I loosened the fuel line connection (nut) on the driver's side (#10 in the diagram below) and the fuel line separated from the fuel rail easily. However, i've backed the nut entirely off of the threaded part on the passenger's side but the fuel line (#16 in the diagram below) will not separate from the fuel rail. Is this a compression fitting that is stuck? I don't want to pull too hard and ruin the fuel line. Any help would be appreciated.
