Old 01-18-2021, 07:39 PM   #3
elgyqc
elgyqc's Avatar
Check this out, sounds like you have the same problem as I had.
You can't "... push down on the push lock pin to release the lock assembly from the steering column" if the bolt is jammed in the extended position.
Steering locking mechanism problem - how I resolved it.
Good luck!
Grant
