Old 01-17-2021, 12:04 PM   #1
TangoBravoNovember
New owner, ignition barrel removal (I'm sorry for the 1000th ignition thread)
Just bought a silver 98 Boxster 5 speed. I've seen a video of it running, but as soon as I got it the battery was dead and key wont turn in the ignition.
[see video 1] The key remote works, and it works in the car's other locks. The key will turn SLIGHTLY in the ignition to where it can't be pulled out, but not to position 1. The steering lock is engaged, turning the wheel doesn't seem to help. Removed the electrical part at the back of the lock, no change. Ordered the audi replacement part.
Trying to remove the lock barrel. Removed the torx screw near the front of the lock, and the 10mm at the steering column. Is there anything else holding the barrel in place? [see video 2] The barrel is loose but can't be removed. Feels like it is stuck in the steering column. When I pull the wheel to one side the barrel tightens up and can't be moved, I do so twice in the video. Is it possible to remove the barrel with the steering lock engaged?
I can't removed the cylinder portion of the lock, because I can't turn key to position 1 to insert a paperclip in to the release hole.
Any suggestions?
Thanks!
Videos
https://photos.app.goo.gl/v7c5Ndh19fayCUJE8
https://photos.app.goo.gl/NpriZjCudPjhj3Fe8
(the dash is lit up in video 1 because I turned on the lights, not because of the ignition.)
TangoBravoNovember is offline   Reply With Quote
