Old 01-13-2021, 08:43 AM   #1
986Hawk
A4 7.5 fuse keeps blowing
Hello! I have a 2000 Boxster I bought in the Fall and had some lighting issues. I searched the forums here and afterwards I replaced the headlight switch and all the crazy lighting issues went away. I replaced that switch a couple months ago. Now, I have a new issue. The left side daytime driving light is not turning on and the left rear tail light is not turning on either. Brake lights work, turn signal still works as well as backup light. I replaced the A4 7.5 amp fuse and it keeps burning out. When I turn in the headlights the blue high beam indicator light lights up but is dim. It stays in a few seconds till the A4 fuse burns out and the daytime driving light on the left goes back out. The left side marker light also goes out. I have replaced bulbs and fuses and still have this issue. Could the headlight switch already be bad after only a couple of months? The only light that will stay on in the left rear is the fog light if I pull the switch out to the second click. Could this be an issue with the arm controlling the high beam switch? Could it be a relay? Any suggestions will be appreciated!
986Hawk is offline   Reply With Quote
