Old 01-11-2021, 10:02 AM   #18
mtb50
Someone sent you on a wild goose chase.
I’ve been watching your posts. If you want to fix your window problem, start at the immobilizer. Best of luck.
Ok so what do I need to check on the immobillizer? Here is were I'm at . There are 3 pins in the middle of the switch. A BRN/GRN/BLK wire coming from the top relay should be hot and it's not. I've gone to the middle pin with a hot wire and the windows go up and down. The top relay does power the top but not the windows I'd appreciate any help
mtb50 is offline   Reply With Quote
