Hello 78F350,
Good timing. This is my next step. After doing some research, I think my problem is the cables that connect to the top motor and trans. I hear a power/clicking sound from the motor. Did some research on the board and saw Maurice (Schoir) pinpointes this area with a possible faulty cable with a power sound and no top movement. Maurice has been awesome over the years with advice.
My question is this, with the top down, I'm not sure if I can reach those clips. I should be able to pop the ball joint or get to that 19mm bolt?
