Old 11-29-2020, 10:03 PM   #1
pilot4fn
Removing the Alarm Control unit
Started a new thread with bettern describing name.
Original thread with only couple replys is here: Removing M535
I just placed my car (2001 Boxster 2.7 with Manual transmission) in to winter sleep.
There is some issues with key fob remotes not communicating with the M535 unit and it has been verified that key fobs do send good signal. Regardless of the previous, Porsche dealer could not pair the M535 with the key fob remotes.
For the above reasons, I'd like to take the M535 unit out from the car and inspect it if there is water damage etc. If needed to, get unit sent to be repaired.
Before the removal, the plan is to disconnect the battery ground, remove the frunk latch lock 'hook' from the frunk lid.
Should I do something else or take something else in to consideration before removing the M535, so I could install it back later on without too much of grief?
... so have some connection issues between the key fobs and alarm control unit (ACU). Key fobs do send the signal as inspectedby 'Keyfobrepair'. Regardless of this, Porche dealer could not get the connection to work between the key fobs and the car.
I got the ACU out today and Looks like the ACU is fine - does not have any sign of moisture in it. Also the pins on the connectors and plastic box is super clean inside out.
Both, the ACU and fobs were replaced on 2015 by previous owner due to water damage in old unit. So, the current unit looks real good maybe for a good reason.
It is just amazing that the keys do not communicate with the ACU - not even with the attempt by Porsche dealer...
Could there be any other fault possibilities to check before ordering a new fob from Porsche dealer?
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
