Old 11-25-2020, 10:42 AM   #1
Gelbster
Power Steering problems -cheap hack
There is an interesting hack to prevent power steering leakage due to over-pressurization. Apparently there is a nasty Check Valve that can stick shut.
Power steering troubleshooting help
The fix is to eliminate it.
Does anyone have the details?
I presume the simplest fix is to just 'gut' the check valve ?
http://www.********************************************.c om/porsche-parts/hardparts.php?dir=986-97-04&section=403-01
Anyone got some details on how to do his and exactly where is the check valve? Auto Atlanta do not identify it in their diagram linked above. I couldn't find it on Pelican:
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=check+valve+power+steering
The other hack/ultimate fix required is to REALLY seal the joint between the Reservoir and the pump. There are lots of "O" rings offered but the real problem is the wobbly twist-to-seal fitting .It tends to be a sloppy fit and wobbles loose so even with an OEM "O" ring in perfect condition it eventually leaks. Permatex?
