Old 11-22-2020, 08:14 AM   #1
jsceash
jsceash's Avatar
Long time member, I would suggest you look at the vacuum tubes. If that isn't it check your intake from the filter canister to throttle body. The tubes age and crack, a black 1/8" od. tube starts under Passenger side manifold (vacuum solenoid) to a splitter under the passenger side "T" coupler. onto the bottom of that coupler. then to the driver side manifold sensor, and then the front crossover tube butterfly valve. If you have a auto trans then the "T" is a 4 way with a tube going to your transmission.
This is the intake from a donor "S" tiptronics motor. which was the base for my LN 3.6 build
