Fault code 4216 and 4460
Hello everyone,
My 2002 base boxter is having problems with the ABS and PSM system. When I interrogated it with my scanner I got two error codes: 4460 and 4216. The latter indicates that the sensor of the left rear tire is failing. Do any of you know what the code 4460 means and is there any way to determine the part number for the speed sensor compatible with my vehicle?
I had problems with the part number of the oxygen sensor, my car is 2002 but has early oxygen sensors, could I have the same problem with the speed sensor?
One more thing the oxygen sensor located in the same side is falling is it related?
I would appreciate any assistance and thanks in advance
Regards,
