Old 11-09-2020, 07:12 AM   #5
Paul
Porsche "Purist"
Paul's Avatar
Not really sure how much the values can be out of range. This car had an intermittent issue which was finally resolved by replacing a corroded pin on DME plug IV.(7.8 DME) It caused a problem usually when the humidity was high.
As you can see from the pictures at the time I was troubleshooting this, the throttle angles were the same for both pots even though the voltages were not 1 and 1/2. I have not seen a sensor failure yet. This owner had already replaced his sensor to no avail.
1987 924S. 2002 996TT. PST-2
