Old 10-25-2020, 03:00 PM   #1
Ohtwo986S
Tail light issue
So I seem to have a pretty odd tail light situation going on. I’ve searched everything I could find online and didn’t really get anywhere.
My taillights light up in every spot except the passenger side brake light. (The main one that lights up when you turn your lights on) So I went to autozone today to replace the bulb (5007 part number) and upon removing the light assembly from the trunk I saw that tail light bulb wasn’t even installed. Just an empty space.... so I’m like ok that’s odd. I put the bulb in thinking that’ll solve that but when I turned the lights on the tail light was still out.
Also.... my brake lights light up but when you press the brake pedal they don’t brighten. So again, they light up no problem, but don’t do anything when you apply the brake pedal. Also, the third brake light DOES function properly. (The one above the trunk) Oh and I did check the fuses already and they are ok.
What is going on?
Ohtwo986S is offline   Reply With Quote
