			OK...I trashed both Tie rod end boot and wishbone boot as well so I'm going to just replace them. Seemed the ball joints were very easy to move around so I think they were shot anyway(someone agree with me!!!) Is it necessary to replace the hub bolt? Should I consider replacing anything else while I'm in there? I'm just going to replace the wishbones and tie rod ends. I dropped the carriers off at a machine shop to get the old bearings pressed out and new ones pressed in along with the hubs. I've read that the printed side of bearings go to the inside and also the opposite....does it matter and will this shop guy know which way if it does matter as I do track the car.****Thanks V
