Old 09-17-2020, 06:10 AM   #19
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by berni29 View Post
Hi
With the cover off you can both test the bearing and see if it has been replaced.
You can bodge the install of an IMS bearing pretty easily. Either by being rough with the IMS shaft and/or the bearing during removal/fitting.
You do not need to spend much money on a new bearing $10 or so will secure you a top quality original type.
Berni
Source for bearing? Burner’s blog specs the bearings pretty well, but it has to be perfect and robust. I would expect to pay 40-60 bucks for the bearing and still not be comfortable. Peace of mind made me buy from a source I can’t remember, but was several hundred dollars for a cylindrical ceramic. The stakes couldn’t be higher in this case.
As for the job, taking the bearing out will ruin it, but freezing the new and gently heating the engine case let’s the bearing drop right in. Just be gentle and it’s easy.
