Old 09-17-2020, 04:21 AM   #2
berni29
Hi
With the cover off you can both test the bearing and see if it has been replaced.
You can bodge the install of an IMS bearing pretty easily. Either by being rough with the IMS shaft and/or the bearing during removal/fitting.
You do not need to spend much money on a new bearing $10 or so will secure you a top quality original type.
Berni
berni29 is offline   Reply With Quote
