Old 09-09-2020, 08:38 AM   #4
steved0x
steved0x's Avatar
There is a gasket between the horizontal baffle and the deep sump spacer, but that horizontal baffle has sealant gluing it to the engine (that's how I installed mine, I wish I had put the gasket as the final piece between the whole assembly and the engine, but it didn't work that way.) I think you will have to try and get a wedge in between and pry off that flat plate. I would expect that the pan bottom and spacer would come off once you took the bolts out. Maybe it was installed using sealant between all pieces?
