Thread: No start
Old 08-31-2020, 11:44 AM   #1
BoXXter
No start
Hello 986ers, hope evrbdys safe and well!
Hope someone had already come across this issue and would point me to the right direction. My 986 S cranks but won’t start. It runs well prior, out of the blue won’t start. No warning, no CEL code. Checked fuses, sensors, it has spark, starter, MAF, CPS. Did fuel pressure test, no pressure. Checked for fuel, no fuel. Jumped fuel sensor socket, pump didn’t run so I changed the fuel pump thought that was my issue but no luck. I can hear the pump turn on but doesn’t run when jumped, should it just run? It seems something is hindering it. Is there any other sensors/parts that not let it run? Miss driving it already. Been researching forums, but still no luck. Appreciate all help and suggestions! Thank you all, stay safe and well!
BoXXter is offline   Reply With Quote
