[QUOTE=1PorscheBoxster986;622755]How is the airflow when changing fan speeds with the accordion ductwork removed as I suggested? This ductwork connects the air flow from the center console to your driver side vent.
I would remove the cabin air filter to see if that's the cause if you didn't have this issue before.
I tried to post a response, not sure where it went.
But I pulled the ductwork you mentioned, and there was no change in the lack of airflow. The motor still increased as i went from low to high, but there was no change.
Any other thoughts?
