				Air volume at the dash vents...
			I noticed that when turning the fan up, I can hear the fan motor increase in speed, however I’m not feeling the increase in air coming from the vents.
I have made sure the vent roller was in the open position, and all of the buttons for the dash, upper, and lower vents were lit. I cycled through each individual vent while also changing the speed.
I thought i had read, that the ignition switch could be a culprit, but I have already replaced it. I’m not sure if its the resistor, because as i said previously, I can hear the motor change speed.
So the easy question is:
What’s next?
Thanks in advance.
Sorry, I forgot to add info on vehicle:  1998 Base Conv.
						Reason: Forgot vehicle info
