Old 08-12-2020, 08:41 AM   #1
BoxPaulie
North East UK
986/996 dash speaker adapter
hi guys.
I have designed an adapter/bracket that allows you to fit any(*) 4" speaker to the dashboard of the 986/996 without having to butcher the existing speaker, remove the tabs or glue a new one in.
*the drivers side (UK) has a specific shape in the dash which creates criteria for your speakers. The cone depth can only be a maximum of 43mm deep, the magnet needs to be a maximum of 70mm in diameter and the mounting face/platform needs to be a maximum of 1.5mm in depth as they are under-slung mounting. If you go beyond this criteria then you WILL need to remove/trim a plastic cable cover inside the dashboard. Please message me for more information and pictures on how to do this.
Heres a video of installation on my youtube:
Rear speaker bracket and grill adapters
Drop me a message or just post on here and i'll respond when i can.
Cheers guys.
Paul
Last edited by BoxPaulie; 01-15-2021 at 02:03 AM. Reason: new ABS version replaces previous PLA version 14/12/20
BoxPaulie is offline   Reply With Quote
