Old 08-02-2020, 01:41 PM   #10
JFP in PA
Originally Posted by Frodo View Post
So John, do you just “recognize” when there are different fasteners in place and adjust accordingly? Keeping in mind that it may not be obvious whose fastener it is? Just seems like a lot to keep track of. (I’m talking especially the second time around, when you’re not the one tightening that new fastener, when it’s now greasy and grungy and hard to id.)
Do most mechanics recognize LN drain plugs and know to back off on the torque applied?
And…do you use a torque wrench when you do them?
And…if not, are you gonna start?
With fasteners, they are visually different, so it is obvious. As for the drain plugs, LN’s are not marked, while others are, so again it is obvious to an experienced tech.
In my shop, if you are not using an appropriate torque wrench, you won’t be working here very long. Every fastener and drain plug is torqued to specs, period.
