Old 07-12-2020, 07:19 AM   #16
Jasper7821
I did the cable tie fix and it didn’t make a difference, the green plastic pieces were in perfect condition so I didn’t want to cut it off and put the cable adjuster on.
The window still goes down the same amount when pulling the handle as before and the door will open without binding but it would be nice to get it to drop the correct amount.
After I put the cable tie on, I now hear a little grinding when the the window is almost all the way up.
Just seeing if there’s another trick, or should I just cut the green plastic piece off and try the cable tie.
It was really easy to remove the door panel so if I have to try a few more times, it’s no big deal.
My friend has the same problem and he put a pen cap between the bracket and green piece and that fixed his.
Jasper7821 is offline   Reply With Quote
