Thread: Start problem
Old 07-07-2020, 12:56 PM   #1
egx
I assume that you mean that the electronics turn on when you turn the key, but the engine won't turn over.
I'd start with the clutch switch since its easy to jumper it to see if the situation improves (or easy/cheap to simply replace). If you jumper the clutch switch be sure to have the trans in neutral if its a manual 5-spd when you try to start the car!
If that doesn't help, then I'd replace the electric portion of the ignition switch (depending on your flexibility, it can be a bit of a PITA).
thanks a lot! i tried pushing harder on the clutch and changing the floor mat and helps so ill try your solution. thanks!
egx is offline   Reply With Quote
