Originally Posted by Liamray
Had the same problem on my 2001 Boxster and I did the bicycle cable adjuster fix, and it works perfectly and has been for 12 months now. Buy yourself a $5 bicycle cable adjuster and spend half an hour fitting it, and your problem is fixed.
Thank you, was going to try cable ties but looks like a cable adjuster may work better.
Is there a certain size I need to look for? I know I need a slotted one so it will go over the cable without taking it apart
