Originally Posted by yfz/700R
thanks for the quick replies, audioguy thanks i will try that. mnboxter they do it on their own, i just shift really quick
You speed shifting, I use to do that in my Eclipse GST. It really does a number on your syncro's. Try not to do that too much. I cant even shift moderatly fast from 1st to 2nd in the 6000 rpm range without the syncro's grinding. Other gears dont grind.
Im going to try changing the gear oil with Royal Purple 75w-90 and hopefully it'll help some...Im hoping my gear oil is pretty old and the new gear oil will cure some of the grinding.
