Old 06-24-2020, 09:13 PM   #12
Jasper7821
Originally Posted by mgfranz View Post
You may want to look at the door latch assy as a potential fault as well. 90% of the "window won't go down 1/4" when I pull the handle..." issues are caused by faulty door latch switches. You can get a used one for around $35-40 and not to difficult to swap out.
Lots of ways to verify if the latch assy is bad, the window won't drop, door won't lock with the fob, Central Lock Mechanism error in Duro...
Thank you for the reply, the door latch seems to work just fine. It locks/unlocks fine with the remote. Also I can hear the motor move when I pull the door handle, the window just doesn’t lower that 1/4” or whatever it is.
Jasper7821 is offline   Reply With Quote
