Thank you for the replies, I really appreciate it. I'll search the links and see what I can find.
I wouldn't think it would be a microswitch as when I pull the door handle I can hear the motor and see the window try to move down. And with the window switch I can toggle it back and forth and the window follows as it should going up or down.
Looking at the prior owners service records, one says driver door not dropping when opening door. They replaced the window regulator and fixed it. It was a $1,000 repair.
Hopefully I can fit it for much less.
Also, does it really need to be fixed now. Do they get worse and not work at all. I have no issues with using it how it is now. If I open the door slowly, it still goes down far enough to not get hung up on the roof. If it stays that way I'm totally fine with that and can spend money on other repairs.
And I read the article and doesn't look too hard to do.
