Old 06-12-2020, 09:38 AM   #2
JFP in PA
Originally Posted by Brian Minson View Post
Morning JFP, here is a link to the video/screen shot of the codes for the engine, the alarm and the seat bets.
https://youtu.be/GwYZS2WnA_A
Thanks for taking a look and giving me some direction on this issue JFP.
Brian
OK, looked at your video, and here is what I see:
-You have an electrical fault in the alarm system, should be seeing voltage at a terminal and it does not.
-You have the famous seat belt fault, which can often be cured by cleaning the electrical contacts in the buckles,. but if that does not fix it, there is a TSB out there with updated components to fix it. This may also be the electrical fault the alarm system is seeing, but that is not guaranteed.
- You have either a disconnected or no longer working safety switch on your clutch pedal. You can check this easily under the dash, and use a multi meter to test the switch to see if it is dead.
I would check the pedal switch and fix it, then clear all these codes and see what comes back.
