Old 06-11-2020, 07:05 AM   #1
selaliadobor
Removing ignition assembly and/or steering wheel lock without key
So yesterday I posted about rescuing my Boxster with no remaining keys, thought I had beat the system when I figured out a plan to cut my key out of the loop when starting the car...
But when I went to look up how to remove the ignition lock, the first step was put in your key and turn it
Ideally what I want to do is remove this thing:
from my car without a key, is that possible?
If that's not possible, can I at least disable the steering wheel lock and wire up my switch elsewhere?
(Or do I even have to remove the steering wheel lock? I was wondering, does it automatically unlock if the car is running? Or does the key physically remove the lock)
selaliadobor is offline   Reply With Quote
