Also added the 997 oil cooler. The wires go to a switch/Gnd the engine bay fan and relay for the cooler fans, and a pressure sender on oil sump and an additional sender on right head. the floor was cut out under the cooler blows down the right side of the transmission. the 2 air checks in the trunk rear corners were removed so air can come into them while fan runs as well as 8 hole in the front wall. You can see one at thw front end of the oil sump.
