Thread: I was surprised
Old 05-26-2020, 05:23 AM   #1
Berryhill
Originally Posted by AZ986S View Post
Even just a top end refresh. New head bolts $250, all gaskets seals $300 ... Then sensors, water pump etc... That's if the bottom end is ok. If not then you are looking at $4k for a decent rebuild without new cylinder liners. The issue with these engines that I have found is lack of affordable aftermarket bearings and the fact that the crank case can not easily be reused if dammaged. This has been debated ad nauseum but if you rebuild you know what you have vs a used engine that has unknown history.
I'm probably going to say it a supply and demand is the reason there's not much aftermarket parts, plus learning about the cylinder walls creates a problem. I can't believe I engine with 100k can cost more than I give for a car.
Originally Posted by BFeller View Post
Common issue is the front engine mount. It is just below the front pulleys on the engine.
I'm gonna get back under there and look. Engine rocks forward so I assume it is the front.
Berryhill is offline   Reply With Quote
