Old 05-19-2020, 11:32 AM   #3
JFP in PA
Originally Posted by SpenceBoxster View Post
I have a '97 Boxster. The A/C is not working. I took it in to have the system properly charged, but it still does not work. The mechanic said that the compressor is not getting any power to it. He said there are no error codes and ll the fuses look good. I have an appointment for him to do a deeper dig, but was hoping to be able to identify the problem myself.
Any suggestions where to start?
s a side not neither of my key fobs work, I have tried all the tips and trick and cannot get them to work. I am not sure if this is tied to it at all. I do have an aftermarket radio and have had a car audio place ensure it is all installed correctly so I am not messing anything up there.
Any help would be much appreciated.
The AC system has two "safety" switches that prevent power from being applied to the compressor clutch;, both are pressure switches, one for too high gas pressure, the second for too low gas pressure. Most likely, one of these is engaged. Start by running a system pressure test.
