Old 05-19-2020, 10:41 AM   #2
blue62
Originally Posted by SpenceBoxster View Post
I have a '97 Boxster. The A/C is not working. I took it in to have the system properly charged, but it still does not work. The mechanic said that the compressor is not getting any power to it. He said there are no error codes and ll the fuses look good. I have an appointment for him to do a deeper dig, but was hoping to be able to identify the problem myself.
Any suggestions where to start?
s a side not neither of my key fobs work, I have tried all the tips and trick and cannot get them to work. I am not sure if this is tied to it at all. I do have an aftermarket radio and have had a car audio place ensure it is all installed correctly so I am not messing anything up there.
Any help would be much appreciated.
Your mechanic says the fuses look good!
That doesn't tell you much.
Is there power to the proper fuse?
If not you have to find out why not.
If there is power to the proper fuse.
Then is there power to the A/C switch?
And on and on and on.
You have to trace the power from the power source (Battery).
To the end source (Compressor).
Could be a faulty switch, wiring, connection, relay, fuse, ground.
