Old 05-17-2020, 12:10 PM   #4
JFP in PA
Are you referring to the indicator light on the cluster that shows the top is not fully repositioned?
On the 2004 models there is a small three pin wire connection that goes to the convertible top transmission on the left side. Jumping the brown and brown/black wires should make it indicate the top is closed.
See my posts in this thread for pics and more detail:
Stuck Convertible Top - Manual operation...
Also, consider removing the relay for the top... I think that works too.
Do you have the part number for the Amp plug you used to make the jumper? With more of these older cars having this issue, it would make a handy diagnostic tool to check if it is the switch before replacing the transmission.
