Old 05-11-2020, 05:23 AM   #5
jsceash
jsceash's Avatar
I track and change oil often. I believe if you do some research you'll find Mobil changed there formula of the oil in the last 10 year due to federal guidelines on emissions. It is designed more for the newer models. Motul although more expensive is a better formula. and then there is always the Gibbs DT40. both are 5-40 blends.
