Also, you might want to remove the 2.5 secondary air injection pump (SAI) and install the SAI line blocking plates (this may or may not have been done on the 2.7 but you might want to do it on the 2.5).
Or you can just remove the pump and then plug the existing hose. That will at least get rid of the weight of the pump.
