How mechanical are you? I see you got it to that point. Mine looked exactly the same. I sent the block halves to L&N to sleeve It's about $4500 and 2 months. You can reassemble with $1000 in special tools. Parts seal kit from Ebay $300 and a service manual PDF. I have a 99-02 copy you can have. Rod bearings are about $100 a set. Piston rings, Pistons, wrist pins come in L&N package. $45 Harbor freight engine stand, and a $119 jack-table, $100 for a jack and jack stands, which I'm guessing you already have since the motor is out.
I neglected to say you may a tune $1000 to 1500. There are several dozen folks on here that have done this with good results my self included.
Good Luck
