Old 03-28-2020, 06:59 AM   #11
jsceash
jsceash's Avatar
Wanted to drive the car some on the street so removed -Chamber from setup back to -1 front and Rear and did basic pipe alignment I use at the track if I'm changing anything. which is band a conduit to the rear tires. measure the pipe at the hub on the front wheels, balance with adjustable rear toe-link. measure distance from the face of the tire side to side front and rear of the front tires. then do the same for the face of the tire to the pipe. Verify chamber with a wheel jig and digital inclinometer. No Idea at this point if or when I'll be tracking the car all events are being canceled thru May.
As far as the Covid thing I fall under the high risk group with active cancer and treatments that slightly suppress my immune system. So I'm at home waiting this out. I try to only watch local news because the national new is so obviously negative and definitely tainted. I know the situation is volatile but there are good thing happening as well as the stats. But if your using stats then validate your report and use all the stats Italy has 60 million people USA has 332 million legal people and as many as 2 million undocumented. The percentages still have our outbreak better controlled than England, Germany, France, and Italy, in number of cases and percent fatalities. If you believe any stat from China, where this virus did originate, or Russia, or North Korea you are a "FOOL".
I wood work so I have been doing some project one for work, one for my sister, and two for home. Watching Netflix and Sling. and I got addicted to XBOX 1 Forza 7 and others Horizon 4 is iffy but I play that to with a digital force feedback wheel and pedals. Column shift paddles.
jsceash is offline
